wiring
Old Aug 2, 2004 | 10:05 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
wiring
OK,
I got the motor in and everything hooked up the carb, fuel lines , exaust-ext-- i removed the tpi computer and the wirring to the tpi from the car.
now here is the challenge when I turn the key on I have no power to my heating and air unit or fuel pump. I do have power to all the lites, radio-tape, and the coil. The fueses are good.
whats up with this 1987 TRans AM, I want it to go to paint so I can cruz it!
thanks in advance
rick
Old Aug 2, 2004 | 10:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
fusible link
Old Aug 2, 2004 | 04:39 PM
kevinc's Avatar
Car: 1982 Z28
Re: wiring
Originally posted by Rick King
OK,
thanks in advance
rick
Your fuel pump was relay-controlled by the TPI ECM, so you'll need to build a way to switch power to it without the ECM there.
Your heater/AC blower fan is powered by a big red wire off the TPI's engine harness, which you removed. You'll need to find the connector on the blower fan harness, and get a fused 12VDC feed to it.
-Kevin
Old Aug 3, 2004 | 11:21 AM
Rick King's Avatar
Car: 1987 TA
:hail: :hail: :hail:
THNAK YOU KEVIN!!
That makes sence to me now
later and
GB
rick
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
