TBI-LT1 TB cable?
Old Aug 3, 2004 | 08:14 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
TBI-LT1 TB cable?
All of you TBI to LT1 guys, got a few questions. What do you do about the throttle cable? my stock one is almost long enough, but not...can I use the LT1 cable? Also, the LT1 had an auto, can I plug the VSS connector from the auto harness to my T56?
Old Aug 3, 2004 | 10:47 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Get yourself a new tpi cable for a 92 , no the connector is different, go to the parts store and get a replacement water temp sensor plug, should be a HELP part.
Old Aug 8, 2004 | 11:19 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks man, I'll check that out. Also, when switching fuel pumps from TBI to LT1, I noticed that the sender from the LT1 tank was bigger than the TBI one. Would a metal tank from the '94 Z28 fit in my thirdgen with no problems? Or should I just swap the fuel pump itself onto the TBI sender and put the TBI tank back in?
Old Aug 9, 2004 | 11:24 AM
TexasLT1's Avatar
Car: '92 RS
Just swap a TPI pump onto the TBI sender and you're good to go.
Old Aug 9, 2004 | 07:18 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
That's what I did. Also, FYI, the LT1 throttle cable is almost a direct fit. It just takes a little tweaking!
Old Aug 10, 2004 | 08:29 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
anyone have a part number for the LT1 cable? I can't seem to find that info anywhere. TIA
Old Aug 10, 2004 | 06:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Why ask for the part number for the LT1 cable when the late tpi one requires no modification ?
Old Aug 11, 2004 | 06:41 AM
jwscab's Avatar
Engine: Many
OK, how 'bout the part number for the late model TPI cable?
I'm going from a different style throttle body to an LT1/late TPI set-up, and getting things is easier if I had the part number.
thanks!
Old Aug 12, 2004 | 08:19 PM
jwscab's Avatar
Engine: Many
no one knows the part numbers for either cable?
Old Aug 13, 2004 | 12:56 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Mine was in stock when I went to the dealer and probably do have the number somewhere in all the reciepts. I'm sure you aren't going to have any problems.
Old Oct 15, 2005 | 06:53 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I bought the 92 tpi throttle cable but it doesn't quite fit in right. Does anyone have picture of how they fanagled it in there?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
