LT1 swap Auto/T56
Old Aug 7, 2004 | 08:45 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
LT1 swap Auto/T56
Is it possible to swap a LT1 that was originally in a a manual car to a 700R4? How much more work would it involve? Thanks
Old Aug 7, 2004 | 11:00 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I don't really understand. Is your thirdgen an auto (700R4), and you want to swap just the LT1 in, and mate it with your auto? If so, yes it's possible, you just have to get a flexplate that goes to a 700R4, and possibly different starter.
There's nothing different about the LT1 engine itself, just the flexplate (auto) or flywheel (manual).
Old Aug 7, 2004 | 11:01 PM
Car: 1988 T/A WS6
yes that is how it is, I am sorry for being vague. Besides that flex plate, I would also need a computer from an automatic car right?
Old Aug 8, 2004 | 10:24 AM
94zsson's Avatar
Car: 87 Z28
Engine: LT1 Hotcam motor
no you dont need an auto computer
when you stick a 700r4 behind a LT1 it is just like having a T56 behind it
you dont need anything special
Old Aug 8, 2004 | 11:12 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Just get an LT1 throttle body from a '92 or '93. Those are the only years a 700R4 was behind an LT1.
Old Aug 8, 2004 | 01:21 PM
Car: 1988 T/A WS6
so all I need it a throttle body from a 93? Is there one available aftermarket or should I just hit the yard? Thanks
Old Aug 8, 2004 | 05:57 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yeah it will bolt right up, you need an auto flexplate of course, you'll also need the throttle body, throttle cable bracket, and TV cable from a 93 f body.
After that you need a way to compensate for the different vss pulse to the pcm.
Old Aug 8, 2004 | 08:00 PM
Car: 1988 T/A WS6
And how would I go about that?
Old Aug 8, 2004 | 09:00 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Couldn't you just get the computer from a '92 or '93 auto LT1? Would that work, since the computer would recognize the VSS signal from the 700R4, since it originally came with a 700R4?
Old Aug 8, 2004 | 10:26 PM
Car: 1988 T/A WS6
I was originally thinking that using a 93 computer would work, but in that case, should I just find a whole motor from a 93?
Old Aug 8, 2004 | 11:30 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
They still used the different pulse VSS IIRC, even the T56 and 4L60E use two different pulses, i guess if your dead set on a non electric controlled trans a 4L60 from a 93 behind a 94-97 T56 motor wouldnt be a bad idea, otherwise you've got to get a little bit creative, you'd be best off just getting a motor / auto trans combo.
Old Aug 9, 2004 | 08:49 AM
Car: 1988 T/A WS6
I know there are a few people on here that have used a 700r4 behind an LT1, how did they go about it?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
