It dont feel like 350Hp
Old Aug 28, 2004 | 11:25 AM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
I need some help. i just switched over from tbi to a carb and guys running my same setup are running well over 350hp. i have a stock 350 block, lt4 hot cam, edelbrock air gap, vortec heads, 750 holley, msd box, msd wires and a holley fuel pressure regulator. i know my timing is a bit off b/c it misses slightly. i used a vacuum gauge to set the timing b/c that is all i had at the time. so i was wondering what the heck could be wronge? timing, carb mixture, ect... help please b/c it feels like my 350 tbi i had in there before and it shouldnt.
Old Aug 28, 2004 | 01:52 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What do you have for rear gears, and what torque converter do you have?
Old Aug 28, 2004 | 01:58 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
right now i have a b/m 2000 stall and 273 open but i have a 373 posi waiting to be put in. i know its not the gears though. im thinking maybe my tv cable is not working properly. i tried adjusting it and its not doing what it is supposed to do... making the clicking sound when you adjust it. so i think maybe its that.
Old Aug 28, 2004 | 05:25 PM
EvilCartman's Avatar
Car: '82 Z28
Get the timing squared away and install the new gears.
Old Aug 28, 2004 | 05:32 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Get the timing squared away before you even drive the damn thing. Timing will make or break a motor, literally.
Old Aug 29, 2004 | 01:15 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
:werd:
Old Aug 29, 2004 | 04:59 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
i'd check the timming then check the compression..
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
