Suspension question for LS1 swaps
Old Aug 30, 2004 | 10:51 PM
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
I'm curious as to what people are using for shocks and springs when doing their LS1 swap.
I'm using the Hawks k-member, so I'm going to lose what - 100 to 150 pounds total in the front end? I'm thinking of putting lowering springs in the front to compensate, and I need new shocks in the rear anyway.
What are you guys (who have completed or are in the middle of your LS1 swap) using for springs and shocks?
Old Aug 31, 2004 | 11:30 AM
FLYNLOW92rs's Avatar
DropZone lowering springs all around
You'll need the lowering springs to keep the stock height in the front....
You'll loose more then 100 pounds in the front BTW...
My car sits perfectly even right now, that's with LS1, Fiberglass Hood, removed light bar, aluminum radiator,etc etc
Old Sep 6, 2004 | 02:47 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
V6 Springs all around and stock struts and shocks. Steel hood, no A/C, no Front Sway Bar and alot of other components removed from the engine bay, plus Aluminum radiator. It seems to sit a little bit high, but its not that bad. There is no way I'm going to lower it because the exhaust just cannot go any lower for my preferences.
Old Sep 8, 2004 | 10:37 AM
kevinc's Avatar
Car: 1982 Z28
GM CDB (WS6) front springs, 1/2 coil removed, 34mm hollow front swaybar.
Hypercoil 175# rear springs, aftermarket 1" solid rear swaybar.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
