looking into the 350 swap for my car but...
Old Aug 31, 2004 | 08:32 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
I want to keep the 700R4. How would i go about doing this. I know that part of it is electronic for the lockup maybe? How would i do this. Im going to a carbureted 350. Would i have to keep the computer for the lock up on the trans?
Old Aug 31, 2004 | 09:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
By going carb, you are going to flatline your computer. It won't be able to lock up the torque converter clutch without the input provided by the computer-controlled distributor and TBI throttle position sensor.
However, power will still be going to the transmission (as long as you don't hack up the harness in the process). If you do a search for this topic on the tranny forum, you'll find there are a few different approaches to solving this "problem".
1) Buy a kit from Summit or Jegs.
2) Hook up a manual switch per the tech article on the TGO home page.
3) Use the 4th gear switch port on the tranny valve body to ground the TCC solenoid (that's what the ECM does, provide the ground to complete the current path for the solenoid). You'll need a normally-open, single pole pressure switch to accomplish this function. It will lock as soon as the transmission goes into overdrive, and will not lock in any other gear. The brake switch will still disengage as it does now.
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
milk
Aug 10, 2015 06:26 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
