Help needed to complete motor, tranny and rear end.
Old Sep 3, 2004 | 01:47 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Have the following questions:
What size pushrods do I need?
What size harmonic damper do I use?
What rear gears should I use?
Regarding torque converter, what stall speed should I use?
Regarding the timing chain, should I install the sprocket on the crank dot to dot, advance, or retard it?
What type/brand intake manifold should I use?
Any more info you can throw my way would be helpful. Not looking to street race the Camaro but would like to have some get up and go when needed.
Here is some info as to what I have for the Camaro.
350 bored .040 and balanced
Hyperepuetic pistons
Vortec heads machined for higher lift, screw in stud and guide plates
1.6 Roller rockers, stainless steel
LT-4 Hot cam
454 TBI with 350 injector
1 5/8 SLP headers w/y pipe
3” Catco cat (not yet installed)
Borla cat back
Boxed LCA (not yet installed)
4th Gen. limited slip rear with no gears
KYB adjustable shocks
700R4 transmission
Corvette servo (not yet installed)
Eibach rear lowering spring (not yet installed)
Wonder bar (not yet installed)
Polyurethane bushing kit
Comp timing chain. (not yet installed)
hectre13
Dec 11, 2023 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
