400+HP HSR owners chime in!!
Old Sep 10, 2004 | 11:18 AM
mess21's Avatar
ok heres the deal i'm planing a engine swap and was goin to do the LS1 swap but for some reasons i decided against it. So who out there is running a holley stealth ram setup on a 350 engine and has 400+ N/A RWHP??? if you would please share the rest of ur setup with me ie cam heads etc. or does anyone have a idea of what it will take to make this kind of power with a HSR setup. oh by the way i plan on using a ZZ4 short block as the starting point. thanx
Old Sep 10, 2004 | 01:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The HSR doesn't really support that kind of power. It flows about 425-450 HP; that's around 360-375 RWHP.
Look at the runners.
If you really want that much power out of a FI 350, you'll probably need a MiniRam.
Old Sep 10, 2004 | 02:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a stock LT1 intake can support thoes numbers... hint hint.
Old Sep 17, 2004 | 05:22 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Ummm NO.Holley actually sell a complete set-up with 42pph injectors that will support 670hp.
Old Sep 17, 2004 | 06:05 PM
Rembrandt's Avatar
That doesn't mean that the intake port cross section area, length, and bends will support enough flow for 670 HP, especially not naturally aspirated applications.
Stealth Ram doesn't mean Tunnel Ram.
for turbos or superchargers, those injectors would be useful. otherwise, probably not.
Old Sep 18, 2004 | 09:29 AM
Car: '92 RS Camaro
Transmission: TH400
I guess I overlooked the N/A part,but for forced induction it will support more than 670HP with bigger injectors.
Old Sep 20, 2004 | 03:29 PM
pskel350's Avatar
the hsr can support well over 400 rwhp with a little porting just like anyother intake out there
there are many people running over 400hp on hsr
Old Sep 20, 2004 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no metal to "port" out, to make the runners bigger.
Have you ever seen one?
Show us one. Just one. N/A of course. The highest power one I've heard of so far, was about 420 HP out of a 383.
Old Sep 20, 2004 | 04:13 PM
pskel350's Avatar
many times.....
even own one.....
im not saying that you can take out 5 lbs of aluminum, but you surely can clean them up to flow better
have you ever seen one out of the box? its amazing somebody would use one without cleaning it up first
i've "heard" of setups that make a lot more hp then what our 406 hsr makes, but never seen them. but im still sure they are out there
Old Mar 19, 2011 | 02:02 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Re: 400+HP HSR owners chime in!!
suscribe to mine, i am going to try and hit 400whp, stealth ram 355 30lb injuectors afr 195's etc.. big comp xfi 292 cam.
Old Mar 19, 2011 | 04:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Something tells me that 6-1/2 years later, he isn't still looking (especially since the OP never even came back in 6-1/2 years ago)...
Lbibb
May 5, 2016 12:00 AM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
