Turning a Hyd. Lifter into a Solid Lifter
Old Sep 11, 2004 | 07:41 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
When I go to start mocking up my engine, degreeing the cam, checking valve to pistion clearance, etc etc. I'm going to need a solid roller lifter. The engine was originally a hydraulic roller from 96. I have the old lifters and was going to turn a couple into solid rollers. My question is has anyone ever done this? Any tips on what to use or how they did it?
-Brent
Old Sep 11, 2004 | 12:04 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Hydraulic lifters cannot be turned into solid lifters. You will need the solid roller designed for that motor. Or, if you want, and like I did, get some tall retro-fit solid rollers. Unless its just for a mock up. Then it's ok. But the second you tighten the rocker arms and press the pushrod into the lifter, then it's not ok.
Old Sep 11, 2004 | 02:05 PM
Car: 1986 Iroc
Engine: Afr 408
Inside a Hydraulic Lifter...
Yea, this is just for mock up. I have a pair of light valve springs just for pre-assembly. What I was thinking is replacing the spring with a small steel tube, or shims? Here is a picture, an exploded view.
Attached Thumbnails Turning a Hyd. Lifter into a Solid Lifter-hyd-lifter.jpg
Old Sep 15, 2004 | 07:28 AM
Car: 1986 Iroc
Engine: Afr 408
How do you people with hydraulic cams degree them in then?? or do you....
Old Sep 15, 2004 | 07:45 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
When I checked valvetrain geometry, I took a couple of old lifters apart and washered them up so they would simulate a pressurized condition.
Old Sep 16, 2004 | 12:41 PM
Car: 1986 Iroc
Engine: Afr 408
After some careful measurements I was able to determine the height of the spacer/shim I would need to simulate a pressurized condition. I had some hard material (Delrin, thermoplastic family) rod stock here at work and used a lathe to kinda mill it down to the height of approximately .2020" +/- .0005". Reassembled the lifter and everything looks good to go. Maybe this will help some else make some check lifters for hyd. roller cams.
-Brent
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Gambit TA
Sep 1, 2015 07:27 PM
B_Dubya
Aug 26, 2015 05:09 PM
Cameeeero
Aug 20, 2015 03:06 AM
