Will my fan work?
Old Sep 17, 2004 | 08:26 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Will my fan work?
After swapping engines I read that i might need to change my fan? Right now it's a single fan. should I switch to a double fan?
Old Sep 17, 2004 | 08:31 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
do you still have the computer?
I'm doing an engine swap right now but its a 350. I'm using my stock electric fan, but I'm just going to wire it up so that it turns on when I turn the key.
I would just keep what you have, either install a switch so you can flip it yourself, or hotwire it to a battery source.
make sure your cooling system is above par so you don't have to rely solely on your fan to keep things cool
brandon
Old Sep 17, 2004 | 08:53 AM
Engine: 383 Stroker
It has been wired to the battery forever...and the cooling system is great as well...i guess i'll be fine? I did the V6 MPFI to 350 TPI. WOW!!! What a difference.
Old Sep 17, 2004 | 04:10 PM
Tobias05's Avatar
good to hear all is well...
Old Sep 17, 2004 | 04:13 PM
Tobias05's Avatar
oh wow, eye opener... I didn't realize you were talking about a small block...
... I was figuring it was a 3.4 or something since your car info still said it had a 190.
pleasant surprise
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
