Engine Recommendation
Old Sep 19, 2004 | 02:31 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
I just wanted some people with more knowledge than I about engine swaps to advise me of something.
I want to swap a new engine into my 89 gta eventually and was thinking of a 383 crate motor but the guys at my work were telling me to find an old cadillac motor and rebuild it and what not.
I want an engine with about 450-500 hp and 500 ft tq that gets around 10-12 or better gas milage and can be used as a daily driver
What would be my best route to go?
(id also like it to be adaptable to 5 or 6 speed)
Old Sep 19, 2004 | 10:54 AM
ljnowell's Avatar
Tell the guys at your work that they dont know a damned thing about thirdgens. You dont want to mess with the hassle of a caddy engine in your thirdgen. Go built 350, 383, or 400. They will all fit like a glove.
Old Sep 19, 2004 | 01:51 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
383 would probably prove to be easier and get decent mileage...but all 3 would serve your needs great!
Old Sep 19, 2004 | 03:33 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
383s are good. thay are capable of alot of power. but really like 400s if you can find one. they make a **** load of torque with very little work. with a good set of heads and a nice cam you could deffinately achieve your goals. both are great motors
Old Sep 21, 2004 | 07:54 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
i'd stick with 350's the parts are cheap and plentiful.
383's are a bit of a hybrid, but they have an aweful lot of options headwise now... unless your making a truck motor i'd stay away from 400's
Old Sep 22, 2004 | 11:52 AM
Drakar's Avatar
350 parts work on a 400 just as well (heads intake cam)
obviously the only difference is the short block, but more cubs is always better.
I would build a 400 if you can find one, other wise 383.
are you keeping TPI (stock intake) or upgrading to MR/SR/HSR? or switching to carb?
Old Sep 22, 2004 | 01:54 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Can't use any part of the rotating assembly though.
Old Sep 22, 2004 | 06:17 PM
Car: 1989 GTA
im switching to lt1 intake
Old Sep 22, 2004 | 11:44 PM
NoUseAbleNames's Avatar
lt1 383 with a twin turbo:rockon: better fuel econo than a caddy. twice as easy
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
