305 Vortec vs 350 Vortec Heads
Old Sep 21, 2004 | 10:16 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
All my seaching has been confirmed here that 305 Vortecs will not flow as well as 350 Vortecs and most people suggest just to use a pair of 350 vortecs for a 350 block. My question is, is there anything that can be done to a pair of 305's that will equal if not better the 350's?
I have a 86 Camaro (primarily used for autocrossing, less than 5400 rpm) with a 350 +.020 4-valve relief stock replacement pistions, XR258HR Hyd Roller Comp cam (258/264 adv. dur and .480/.487 lift), shorty headers, Edelbrock Performer intake with a Road Demon Jr. 625 carb. CR unknown. The heads are currently 350 tbi truck heads and either 305 vortecs or 350 vortecs would be an improvement. I was given (free) a pair of 305 Vortec heads cast #12558059 1.84/1.5 valves (64cc?). Obviously I'ld have to get a new intake to use these and to swap out the springs for the ones set up for the comp cam. I am the counterman at a machine shop, and my head man can install 1.94 valves and smooth out the exhaust ports for better flow. Unfortunatly we don't have a flow bench as we don't do much performance work. What else should be done (if anything) to help the 305 heads breathe, or should I just buy 350 vortecs and start from there?
Gary R.
Old Sep 21, 2004 | 11:46 PM
Greenie's Avatar
Car: 1982 Camaro Z28
Transmission: 700-R4
I believe a 305 vortec head is the same as a 350 Vortec head. i dont know. can someone clearify this for me and GMan 3MT!
Old Sep 22, 2004 | 12:03 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
check mortec.com for the casting numbers
Old Sep 22, 2004 | 12:15 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are different but close relatives. They have different chamber and valve sizes. I think most of us 305 guys are waiting for someone to bite the bullit and try a set. There is to much bad info/disscussion out there that keeps us from buying them.
Old Sep 23, 2004 | 12:19 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
it has the smaller 305 size valves and chambers and a similar but smaller set of runners.
Considering the results on this board with the regular 350 vortecs on a 305, just milling a set of 350 vortecs would likely get you where you would like to be.
Old Sep 23, 2004 | 01:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He's considering using the free pair of 305 Vortecs on a 350.
Old Sep 23, 2004 | 02:10 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
From what i understand they have Vortec style intake ports, and do require the Vortec intake.
But they have smaller valves(as stated above) and have a L98 style combustion chamber, unlike the "fast-burn" style chamber on the L31 heads.
Old Sep 23, 2004 | 02:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the smart guy with the funny name that writes in the back of one of those magazines (car craft?) first brought it up then made a retraction in a later issue stating something about the exhaust port or something like that.
I ported a set of 85 305 iroc heads for 13 hours and put them on a 406 I promptly blew up due to an oil pump failure the car was the fastest I had ever owned to this date. then a friend put them on a used 350 shortblock from a 79 vette and won the season championship in the "chevy monte carlo" circle track class.
I figure they cant be too bad. Maybe a stock LT1 cam or other smallish cam, and carb on a 350 they might do well.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
