Carb to Lt1 wiring, some confirmation pls!!!
Old Sep 30, 2004 | 05:13 PM
Drakar's Avatar
Ok below is the LT1 wiring from the dummies post, and I have marked in RED the few connections I "think" I need, let me know if I forgot any? also I have deleted the following VATS/AC/AIR/EGR/CAT/CAHRCOAL Canister.
| | Top White 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is DK GRN and is the coolant temperature feed to instrument cluster.
J is DK GRN/WHT and is fuel pump replay control
H is empty.
G is DK GRN/WHT and is vehicle speed signal.
F is GRY and is fuel pump motor feed.
A is RED and is Alternator feed to instrument cluster.
B is TAN and is oil pressure feed to instrument cluster.
C is BRN and is oil level feed to instrument cluster.
D is empty.
E is empty or if you have a manuel tranny it is the clutch anticipate signal and is GRY.
| | Top Blue 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is TAN/BLK and is (Automatic) torque converter clutch control.
J is ORN/BLK and is (Automatic) park/neutral feed from transmission position switch.
NOTE: If this vehicle is manuel the wire would be LT GRN and would be (manuel) backup lamp feed.
H is LT BLU/BLK and is (Automatic) TCC switched power feed.
NOTE: If this vehicle is manuel the would be be BRN and be (manuel) power from turn B/U fuse # 2 to backup switch and would be brown.
G is PNK and power feed from ECM IGN fuse # 5
F is DK GRN/WHT and is A/C request signal
E is DK BLU and is theft deterrent - fuel enable feed.
D is WHT and is techometer signal to instrument cluster.
C is WHT/BLK and is diagnostic request signal.
B is service engine soon indicator feed.
A is empty.
Black Connector 4 pin
|A|B|C|D|
A is PPL and is ignition (crank starter) (connected to starter relay)
B is BLK/WHT Ground
C is ORN Power feed from ECM BAT fuse #4
D is Empty
I believe these are hooked up because I have these connected via an underhood fuse block, which has power and is already wired up to the rest of the harness. But I could be wrong!!
C100. It's connected to the underhood fuse block.
|A|B|C|D|E|
|K|J|H|G|F|
A is PNK and is power feed from injector fuse 9
B is DK GRN/WHT and is A/C compressor relay control
C is DK GRN and is A/C compressor clutch solenoid feed
D is TAN and is serial data signal.
E is BRN and is Air Pump Replay Control.(connected to AIR-PUMP solenoid relay)-->(RELAY CONNECTED TO BATTERY)
F is BRN and is power feed from FANS/SOLs Fuse 6
G is PNK and is power feed from ignition fuse 11
H is DK BLU and is secondary coolant fan relay control
J is DK and is primary fan replay control.
K is PNK and is power feed from injector fuse 10.
Old Sep 30, 2004 | 10:39 PM
TexasLT1's Avatar
Car: '92 RS
Looks good to me. I can't remember, what are you doing for trans, A/C, and VATS?
Old Oct 1, 2004 | 10:49 AM
Drakar's Avatar
VATS was deleted from PCM.
Trans is a T-5
AC Delete pulley and removed from PCM
PCM is also calibrated to 6 speed.
Old Oct 1, 2004 | 12:43 PM
TexasLT1's Avatar
Car: '92 RS
Ok, then it looks like you should be good to go.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Thirim
Aug 9, 2015 06:19 PM
