305 to 350 (can't find what I'm looking for)
Car: 1985 IROC Z28 and 99 Nissan Altima
Engine: 305 TPI / KA24DE on N2O
1st off I have a 85 IROC with the 305 TPI and I'm going to be swapping it for 350. What I need to know is if I change the injectors and ecu can I use my TPI set up on the 350?
You can use the TPI from the 305 plus other external parts plus you will need the following.
Knock sensor
22# fuel injecters
New chip for the computer (not a new ECU)
Knock sensor
22# fuel injecters
Transmission: 4L80E/4L80E
The '85 TPI ECM wasn't their best effort. You might be better off getting a later MAF ECM while you're at it.
Car: '82 Z28
Engine: 350HO
Transmission: M4
More hardware to change than if you just stick with MAF.
Originally posted by 89FormulaLS1
The TPI setup itself is exactly the same on 305 and 350 engines.
