Roller Or Flat Tappet Block
Old Oct 15, 2004 | 10:00 PM
mcann's Avatar
I have a 350 block with the casting number 14093638. This block came from a 89 1500 pickup with a flat tappet cam. Mortec list this block as 14093638...350...87-95...2 or 4...Roller or flat tappet cam one-piece rear seal. The block has the bosses in the lifter valley for the spider and is machined for the lifter retainers but the lifter bosses are not drilled and tapped. I have a 87 305 roller that this 350 is replacing. I wanted to use the spider and lifter retainers from the 305 with a zz4 cam and new lifters. Can I just drill and tap the bosses to mount the spider or is there something esle that would need to be done to use the factory roller setup?
Old Oct 16, 2004 | 12:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the little towers are present in the new block, go ahead and tap them for the roller hardware.
Don't forget, you will need the factory roller cam retainer plate on the front of the block as well.
Old Oct 16, 2004 | 01:01 AM
JesasaurusRex's Avatar
Re: Roller Or Flat Tappet Block
I did the exact same thing go 4 it itll work
69GTOby
Apr 18, 2016 02:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
RyanJB
Sep 14, 2015 03:39 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
