Tbular Kmember LS1 swap, accy question
Car: 1990 Formula
Engine: 355
When using the tubular Kmember I am assuming that it is not required to be modified in any way for the swap to work out, correct?
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
My understanding is that no modification is required, but I haven't put mine in yet. Contact HAWKS directly - I'm sure they could tell you.
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
It needs to be modified a little bit....Just the bolt holes for the motor mounts. I had to open mine up with a dremmel to get the fit correct and make sure the bolt passes through. If you get the kmember test it on the engine first!! It is 10 times easier to open those holes when the k member is out rather than in...believe me! Other than that everything bolts in easy. Im not any type of fabricator either, im 18 and never done this kinda thing before.
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
im dyin to know what if any ls1 long tubes will fit under there.. id like to and pioneer it but living in canada doubles the price of everything when it gets to my door
Apperently Hawks does...its just not on their website. I guess if you call him he'll tell ya about it. I would love to get some, but I definatly dont have the cash for it.
