new at this
Old Oct 18, 2004 | 11:18 AM
Tger's Avatar
Car: Polo Green 1992 Camaro RS
Engine: 3.1L V6 MultiPort Injection
Transmission: Auto (sadly)
new at this
How hard and how much would it cost me to put an LT1 in my 92 rs v6?
Old Oct 18, 2004 | 11:31 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome abaord. You will find that this is a popular swap for all kinds of 3rd gen modders looking for power, drivability, and gas mileage. Take some time and read through the stickies at the top of this forum. There are millions of posts out there that cover what is involved with this swap along with parts lists and cost totals.
Old Oct 18, 2004 | 12:07 PM
Drakar's Avatar
http://www.geocities.com/texaslt1/lt1swap/swap.html
good place to start.
and welcome aboard
Old Oct 18, 2004 | 12:35 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Just a suggestion, but if you really want a LT1 thirdgen, you should look for a complete TPI car with a blown motor. This will put you much farther ahead in the swap.
You will have the correct suspension.
you will have the correct motor mounts.
You will have the correct fuel pump.
You will have the correct tranny, or at least one you can use.
You will have the correct exhaust.
There's probably more.
Old Oct 18, 2004 | 01:37 PM
Tger's Avatar
what about starting with a smaller v8? would thatbe suggested for a beginner?
Old Oct 18, 2004 | 02:07 PM
Drakar's Avatar
if you mean by 305 instead of 350, then NO!!!!
the size of the engine is not important when swaping SBC, 305 -> 350 maybe even 400 are all the same physical dimensions.
what is considered is induction type, carb is the easiest to swap in, where as LS1 is more difficult. Lets put it this way the mechanical aspect of installing an engine is the easiest part (I have done 1 swap so I speak from experience, that even I can do it) the wiring, I would say is currently my BANE!!!!
If you fear not the wiring, then do the LT1 swap, other wise you could just find a 350TPI car and do some basic mods to it.
Old Oct 18, 2004 | 04:00 PM
Tger's Avatar
I run an electronics busisness, so i dont fear any wire.
