where to find a good 350 1,000-1,500$
Old Oct 8, 2004 | 02:10 PM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
best way to go for an engine swap, new, used, rebuilt???
hey all, ive got a 84 trans am with a 305 in it. i had 2 spun rod bearings and replaced all 8 while i was in there. im not a mechanic but i tried to clean up the crank where the spun 2 were at the best i could. i havent got it fired up yet but im not confident that my rod bearing job will hold, the spun 2 that is. so im looking at getting a new engine. a 350. for not more then 1500$. any opinions of engines sold at say autozone. they have some for 1200 and up. i need to go get specs but other then that donno. gmpartsdirect seems a little high for my price range. any advice is much appreciated, thanks.
Old Oct 8, 2004 | 03:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'd say look at the junkyard or in the newspaper/auto trader. I found a very healthy 350 out of a '79 Z28 for about $400 usd.
Just gotta know where to look really. If you want a new engine though, thats a pretty tight budget. Probably won't find much in the way of high performance for less than 2,000
Old Oct 8, 2004 | 04:12 PM
Orizon's Avatar
Car: 1984 Trans Am
well i talked to kragen and they have someone that will build to specs, 1,00 for a stock 350 donno horses, 2250 for a 350 dyno tested at 350 horses. as far as pullin an engine from a yard or what not, i wouldnt really know how to go about identifying whether its a good engine or not, and im not looking to rebuild. i dont have the means to rebuild and bore an engine myself. thats why i'd rather get something i can just drop in. ive got a couple weeks to figure it out, id love to find a good used engine for 500 bucks but donno that i would be able to. thanks for the advice
Old Oct 8, 2004 | 05:03 PM
Orizon's Avatar
Car: 1984 Trans Am
well i have been scowering the forums and i keep seeing refrences that 305 heads are pretty nice. does that apply to my 84 305 LG4 engine. if so might i do well to just buy a bottom block and keep my heads. im just trying to explore all possibilities to get the most for my money. i can see myself opening my wallet a little wider if its worthe it. i plan on keeping the car indefinetly so would like to do something worthewhile
Old Oct 8, 2004 | 06:18 PM
Air_Adam's Avatar
Yup, LG4 heads are among the good ones if the casting number is 416 or 601. If its original, its probably 416.
Old Oct 9, 2004 | 12:03 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The correct term for that is short block.
It's a matter of luck whether you'd be able to find a good engine for $1000... Your chances are better if you're looking for a shortblock.
It would be better still if you had a crank and block that could be used for a core or for rebuilding.
I have some extra parts that I could sell you for a reasonable price, since you're in Sac and I'm in Eureka.
You can PM me if it seems like that might work out.
I even have a good running 350 that I'd be willing to part with. It's out of a motorhome tho (lo performance).
Old Oct 9, 2004 | 11:46 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i would have to say for 1500$ you could get a realy nice lt1 to drop into your car. look on ebay for a local low milage lt1. i have seens some over on camaroz28.com go complete for 750 with a tranny.
Old Oct 11, 2004 | 11:55 AM
Camaro Project's Avatar
Car: Chevy
Engine: Largest Factory V6 on Earth
Transmission: 700R4 w/ Trans Cooler
I've tried to tell people before-----I can get you a pulled Lt-1 out of an old cop cruiser for about $500. They have the entire cars for sale as well. I'm around Philly. Let me know if you want the number.
Old Oct 11, 2004 | 12:34 PM
bigarmzz's Avatar
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
damn dude...i'd like one of those lt 1's.....for that price...whats the miles like???...
i got a 2wd truck that would love to have one of those...
here's the pic of it....
email me
klambert@cebridge.net
thanks
-bigarmzz-
Old Oct 18, 2004 | 05:34 PM
Marc 85Z28's Avatar
Those engines are usually beat to hell and back. Besides, they are the iron headed version, and make around 25HP less than the F and Y body LT1.
Old Oct 18, 2004 | 06:07 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea they are iron headed not realy a big deal if you dont mind the weight. however the iron heads flow better than the lt1 alum heads. but for the price even if it was beat its still a cheap lt1.
Old Oct 18, 2004 | 07:10 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Are those the baby LT1's or the iron headed version only? If its just the roadmaster iron headed LT1, grab that puppy for $500, buy the aluminum heads for $200 and put the rest into a new cam, springs and rocker arms and you got yourself a nice 350, fuel injected, for only $900-1000.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
NBrehm
Aug 25, 2015 11:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
LittleFranks
Aug 20, 2015 03:55 PM
