fuel pressure question
Old Oct 23, 2004 | 12:40 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
hey will i need to modify the fuel pressure when i swap my motor? (TBi to Carb) if so what will i need .... fuel reg and thats about it right?also can someone tell me the correct PSI?
Old Oct 23, 2004 | 01:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
mallory 4309 (return style regulator). Set it to ~5.5.
Old Oct 24, 2004 | 12:14 AM
rustbird's Avatar
Car: 92 firebird
Engine: A small block something?
I used the the tbi stock pump (12psi) and bought a holley max psi one for $22 bux and a cheap little psi gauge and set it to 7psi and blocked the return line. Hope this helps
Old Oct 24, 2004 | 02:20 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I would not block the return line. The pump can and will eventually burn out.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
