GM PM Rods
Old Oct 25, 2004 | 03:56 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
GM PM Rods
What kind of abuse will the GM PM rods take? I know they are rated up to 500 horsepower, what have you guys put them through? I am trying to keep my build cheap. The Scat forged I-beams are rated to 500 horsepower and 7500 rpm for comparison purposes, although they are made from different material.
I dont plan on shifting this motor much over 6500 rpm.
Here are the specs on the motor for now:
377 (std bore 383)
Probe Industries Forged Pistons (11.3:1 compression)
GM Forged PM Rods
Scat 9000 crank
Ported E-tec 200 heads
Custom Solid Cam (in the neighborhood of 259/269@.050, .599/.620 lift w/ 1.6's)
Car craft made 530 horsepower with a similar motor, but a 350 and it peaked power at 6300 rpm. I would imagine this should see no more than 6800 rpm.
Seth
Old Oct 25, 2004 | 03:59 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Those pm rods are as good as the old "pink rods" but they are not rebuildable like the scats or the pinks, they have a "cracked cap" The mating portion of the rod is not machinable
Old Oct 25, 2004 | 05:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Those are same rods as in the LT1/LT4 style engines and many guys have put over 300hp to ground on those rods reliably.
Same in the ZZ4 series motor with 355 hp and those shortblocks have been built up with numbers approaching 500hp. I wouldnt try 500 hp on those rods but its usually the bolts that fail.
Super AFR ZZ4 has 460 horse at 6500rpms or so which is pushing it in my opinion.
Check This thread out.
https://www.thirdgen.org/techbb2/sho...hreadid=263969
Old Oct 25, 2004 | 06:13 PM
I will be running ARP rod bolts, so rod bolts wont be a factor. Thanks for the input, keep it coming.
Old Oct 26, 2004 | 03:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The number I've seen floating around about PM rods are ~450 crank hp.
About them being rebuildable, they can be "rebuilt." However, from the factory, they are better balanced (as a set of 8). As a rod, they are also a bit more "stable" so they don't really take advantage of shot peening or really any other forms of stress relief. As far as rod bolts and re-sizing, sure. I have a set of PM's with ARPs.
Old Oct 26, 2004 | 05:28 AM
I was under the impression the cracked cap design was not fesiable to rebuild..would you mind explaining how they are rebuilt if they become non-concentric?
Old Nov 7, 2004 | 03:28 PM
LT1guy's Avatar
Car: 1987 Trans Am
I had always heard that PM rods were "as good as pink rods", but personally I'lll never use them again. My 37,000 mile Camaro SS (no power adder, ever) had its #5 rod disintegrate while driving down the road normally several months ago! Oil pressure was good, there was no coolant in the combustion chamber...even the bearings looked great. There was not much left of the rod, other than the ends...the rest was powder! My machinist looked at it and thinks it was poor heat treating, and the former Camaro brand manager, who I talked to recently, agreed...not common, but it happens.
Old Nov 7, 2004 | 09:48 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The older PM rods couldn't be rebuilt, but i hear the new ones can. I knew once upon a time, but its seemed to leak from my brain since then. I only have a finite amount of infintesimal space.
Old Nov 8, 2004 | 02:37 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
They can be reconditioned..i know that for a fact, but it has slipped my mind aswell...anyone that wants EVERY possible fact for LT1/LT4 motors get this book..http://www.eshop.msn.com/search/deta...&prodId=450202
(which i have but its in michigan and im in NY)
there are guys over on camaroz28.com who are pushing over 450 RWHP on stock rods...granted they have ARP bolts/studs...
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
