LT1 swap side effects
Old Oct 28, 2004 | 11:26 AM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
I understand that Lt1's that are put into most 3rd gen cars do not conform to the cars EGR valve/line flow, that you need to block off the EGR valve. This how increases the temperature in the exhuast manifolds and leaves your car unfit for the emission requirements. Is there an inexpensive way to compensate for the increased emissions?
Old Oct 28, 2004 | 01:26 PM
TexasLT1's Avatar
Car: '92 RS
Um, I passed Houston emissions without EGR or AIR and I have LT4 Hotcam and heads. You don't need to block of anything, you can do an LT1 swap and keep all emissions.
Old Oct 29, 2004 | 07:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The Corvette (on the L98 anyway) had the EGR routed outside the heads. I'm sure you could do something like that.
Old Oct 29, 2004 | 08:47 PM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
I have a 94 lt1 from a caprice in my 85z. Took it to the california smog referee and he got me the first time for air intake and charchol canister. Took it back and now it is california legal. Btw, all the stock smog pieces were on the car at the time. Also the motor is bone stock with 155,xxx miles and runs 13.6et
Old Oct 31, 2004 | 12:14 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I have the no EGR(blocked off) and the A.I.R. tubes on my headers are blocked off as well. I passed Illinois emmisions with flying colors. You don't have to block anything off. You can connect whatever is there with some degree of creativity.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
