Which Vorterc manifold to get
Old Oct 21, 2004 | 12:56 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Well I am closer to getting the engine assembled; I would like to get this manifold from GM part #12496820. According the GM Performance parts this manifold will work with vortec heads P/N 12529093, 12558060, 12497186 or 12464298. I have the 062 heads. Looking for a dual plane vortec manifold that is egr equipped. Looking for suggestion.
Old Oct 21, 2004 | 01:02 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any of the performer vortec intakes with an adapter plate should work fine. A good buddy of mine runs that on his vortec 305 TBI. Can I assume that is the engine we are dealing with here?
Old Oct 21, 2004 | 01:12 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
186? Isn't that the old '69 Z-28 head?
Old Oct 21, 2004 | 01:21 AM
86z/92rs's Avatar
I have a balanced 350 bored .040. The only thing holding me back, now that I have the $$$, is vortec manifold with egr provision, rockers and pushrod.
Old Oct 21, 2004 | 01:44 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Care to explain how the EGR setup is going to work? Those intakes listed are specific for a reason: the heads listed have the cast in exhaust crossovers. 906/062 castings do not. They require external EGR setups.
Old Oct 21, 2004 | 09:08 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If he has the GM vortec TBI intake he can use EGR by plumbing into the header. CHP did this on their vortec TBI set-up and it was fairly slick how they did it.
Old Oct 21, 2004 | 03:00 PM
Air_Adam's Avatar
Could probably do it the same way GM did on the Corvette, couldn't he? I know the C4 vettes had external EGR setups.
Old Oct 21, 2004 | 03:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yes, but he's in Cali. Cali being the smog police they are, I believe requires the OEM setup. An external EGR is not OEM.
I don't know if southern California is any different, though.
Old Oct 21, 2004 | 10:50 PM
86z/92rs's Avatar
My car is registered in Michigan but still prefer to have the EGR manifold. If anyone can give me a part # for a such a set up and dual plane, your help would be appreicated. I am already looking at SDPC fort heir TPI version of the EGR plumbing.
Old Oct 21, 2004 | 11:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Any of the part numbers you list should work. There's no such thing as a raised-runner-moreso-than-the-already-raised-runners or anything crazy like that. It's just a matter of, like I said above, the cast cross overs.
Old Oct 31, 2004 | 08:26 AM
contactpatch's Avatar
Engine: sbc 350
Does anyone have a dimension drawing
of GM 12496820?
I am interested in the height of,
block, to carb flange.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
