Heads & Intake
Old Nov 4, 2004 | 11:38 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Heads & Intake
Hey
I am looking at changing my heads and intake this winter. I was looking at the trick flow 23 degree heads that have been cnc ported with a stealth ram intake. My motor now has 10.1 compressiong stock intake and cast iron heads 194 150 valves. How much more performance could I get by swaping heads and intake. The car runs 13.5's as it sits. Any other head options would be great
Old Nov 4, 2004 | 03:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What is the chamber volume of the TF heads you intend to install? If you have 10:1 compression now with 76cc heads, you'd better get the 72cc TF heads.
It should be a very nice pick-up when you get it sorted out.
Old Nov 4, 2004 | 03:25 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I was planning on going with the 72cc heads. The compression will be more but since I will be using aluminum heads I should be ok.
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
