383 suggestions
Old Nov 17, 2004 | 05:00 AM
Gecz28's Avatar
Car: 88 iroc vert
383 suggestions
hey guys. i wanna get an engine together thats makes around 450hp at a low rpm. any suggestions on parts; heads, cam carb?
i want a 355 but the hp would come at a higher rmp so probably a 383. but i need help with parts combos. maybe AFR heads and BG carb for sure.
anyone wanna throw their 2 cents in????
thanx
Old Nov 17, 2004 | 11:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cubic inches.
There is no other choice. HP = torque at 5252 RPMs, and peak torque is typically roughly the same as CID. So, if you want peak HP in the 5500 RPM range, you need lots of displacement. It also helps to have lots of valve lift.
Why not go for a Motown shortblock? Available in 400-434 CID sizes. Not cheap, but reliable horsepower never is.
Old Nov 22, 2004 | 05:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Is a blower out of the question? That will make 450hp a pretty easy goal on a 350 or 383.
Old Nov 22, 2004 | 06:28 PM
Parrydise7's Avatar
GM sells a 383/425 hp crate motor. Check out the parts that GM used, and go from there.
Old Nov 22, 2004 | 09:41 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
this months super chevy danger mouse project is only a 350 but they pulled almost 500 ponies with small 170 heads,but not as much torque as a 383
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Nervous2
Oct 8, 2015 10:53 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
JSDaddy189
Sep 26, 2015 03:50 PM
