newbie question please help
Old Nov 18, 2004 | 06:59 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
hi, i have a newbie question!!! i have a 305 91 camaro lookin to put in a 350. will a 350 long block 2 bolt main 65-85 fit in to a 91 camaro just as easily as a 92 350 motor?????
is the 305 in the camaro a short or long block. also is this a good deal???http://www.midatlanticengines.com/specials.htm thanks for your time
Old Nov 18, 2004 | 07:18 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: newbie question please help
you can use a 65-85 engine in your 91 without a problem you need to make sure that the heads have accessory holes in them for your accessories to bolt onto
that engine in the url you posted what does it have as far as internals and what heads does it have on it ?
need more info to make an assesment weather its good or not
as far as the 305 in your car now the difference in a longblock and a shortblock is
longblock = engine plus heads
shortblock = just the block and internals no heads
Old Nov 18, 2004 | 07:37 PM
jayk2k3's Avatar
Car: 85 camaro z28
thanks for your replay so fast. is there any major diffences in the
65-85 block and 91-92 blocks
Old Nov 18, 2004 | 07:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
65-67 - crank journals are "small" size.
68-up - crank journals are "medium" size.
65-68 - no accessory holes in the heads (as mentioned).
65-85 - two-piece rear main crank seal. Uses a different flexplate than 86-later.
86-later - one-piece rear main crank seal. Uses a different flexplate than 85-earlier.
65-79 - driver's side dipstick.
80-up - passenger side dipstick.
65-86 - perimeter bolt valve covers.
87-up - centerbolt valve covers.
65-86 - all intake manifold bolts at 90 degrees.
87-up - center two intake manifold bolts on each side at 72 degrees, rest 90 degrees.
65-87 - slotted pushrod holes to align valve rockers.
88-up - "self-aligning" valve rockers.
And, the Number 1 difference:
65-67 - no 350's (except a few rare '67 Camaro 350's).
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
