v6 to v8tbi swap questions
Old Nov 24, 2004 | 12:34 PM
ldbaine1's Avatar
HI. I read the swap faq but have a few questions. I have a 92 v6 firebird I want to put the v8 into. I have a 91 v8 tbi firebird as a donor car. Whats the difference between the two when it comes to fuel pressure? Will I need to use a 3 port regulator? Or would it be easier to just change the pumps out.
ldbaine
Old Nov 24, 2004 | 04:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The V6 pump should work with the TBI unit.
Old Nov 24, 2004 | 04:24 PM
Drakar's Avatar
Im gonna say he'll need the pressure regulator as I thought the V6's ran the same PSI as TPI/LT1 and TBI only needs like 15psi?
Old Nov 24, 2004 | 05:04 PM
nsimmons's Avatar
Pressure is made via a regulator not a pump. I ran a tpi and lt1 pump in my crossfire with the pressure set to 10 psi.
You'll be fine with the stock pump, it will have higher flow rating than a stock tbi pump.
Old Nov 25, 2004 | 12:42 PM
ldbaine1's Avatar
So I will still need to run a pressure regulator. And just make sure its set to 15psi. Cool.
ldbaine
Old Dec 1, 2004 | 09:10 PM
nsimmons's Avatar
the tbi throttle body has an integrated regulator
Old Dec 1, 2004 | 11:07 PM
five7kid's Avatar
Exactly.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
