LT1 Emissions...
LT1 Emissions...
I have finally decided on doing a 94/95 LT1 swap. When I get into it, probably am going to do a whole overhaul of everything. I'm thinking of going w/ Lloyd Elliot's Emission friendly cam and heads...BUT, my question to you guys is,
If I go w/ his 1, 2, or 3 kits, will it pass emissions based on our more FORGIVING emissions specs than the newer cars?
To rephrase, since it's a 94/95 engine/electronics...if it is said to FAIL emissions on THOSE years w/ a bigger cam...what would it have to say on specs for a '90 model year car? What's failing to a '95 Car, might be passing to a "90" car...
Transmission: 4L80E/4L80E
Get the requirements for your area. Most places, it's the newer of engine or chassis that defines your requirements. You may be able to sneak an LT1 through as a '90, but more than likely you're going to have to meet the LT1 year requirements.
Car: 1987 Trans Am
Engine: tree-fiddy
I'm for the if they don't ask, you don't tell. And if you think it will fail emmisions, take it to a Jaun and Hector's garage. It will pass there for about $20.
88SS6SPEED
Nov 11, 2015 07:05 AM
