Fuel Pump??
Car: 1991 Pontiac Firebird
Engine: Chevy 350
Transmission: TH700-R4
Fuel Pump??
Im doing an engine swap in my 1991 Firebird, and im wondering wich fuel pump to use. the engine that i am putting in is a Chevy 350 carb engine with a mechanicanical fuel pump. the engine in my car now is a fuel injected V6 with an electronic pump in the tank. which fuel pump would be best for this application? keep in mind this will be a street and strip car.
Transmission: 4L80E/4L80E
The in-tank electric type pump will produce enough volume to supply your engine if it (the pump) is in good condition. You'll need a regulator that includes a return port so the pump is running at full volume all the time. This keeps the pump healthy.
You can also use the in-tank electric as a "pusher" to an engine-mounted mechanical. You'll either need to use a 3-port type mechanical pump like came from the factory on carb'd 3rd gen V8s, or the above-mentioned regulator. Some would argue the regulator should be used regardless.
Engine: Chevy 350
I have herd from some other people before this board that the electric pump could possibly starve the engine for fuel. is there any truth to this?
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
