computer question
Old Jan 16, 2005 | 11:35 PM
bc5007's Avatar
Car: camaro
Engine: 305ci LB9
305TPI to 350TPI upgrade
i have a 1986 iroc-z 305ci TPI LB9 and I want to put in a 350TPI, am I going to need to switch computers? and are there any other parts i will have to replace to put that in? http://www.gmpartsdepot.com/store/pr...&Category_ID=2
Old Jan 17, 2005 | 03:33 AM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
as far as I know you have to get a new chip. Are you swaping any of the parts from the 305 over to the 350? If so the fuel injectors and the throttle body are going to be to small for the 350.
Old Jan 17, 2005 | 08:34 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I did a 305TPI to 383 SUerRam swap last summer in my 91 Formula. Everything wiring wise will fit just fine since you're going from one TPI to another. Just reuse your existing sensors if the 350 doesn't come with them. I probably would anyway (use the old sensors) just to make sure I didn't introduce any possible new variables (at least at first).
The only exceptions to this are:
- the fuel injectors (you'll need 22's instead of the stock 19's on your 305)
- the knock sensor (you'll need one for a 350)
- the computer memcal ("chip"). You need the whole memcal, not just a reprogrammed chip. That way you get the correct knock and limp home mode circuitry. They're avaialble through GM Parts Direct for something like $50.
Since you're going from a small block TPI set up to another small block TPI setup, this is actually a very easy swap as engine swaps go. Good Luck!
- Vern
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
