For you LT1 Swappers...
Old Feb 7, 2005 | 05:20 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
For those of you who've swapped LT1's in, what do ya'll use for Data logging, and tuning? I've got Datamaster EE and OD on my Laptop, but I don't know how to use it. I've got a cable to hook to the DLC, and when I open the program it says PCM Detected. It says I have to open a certain file, and I don't know what file to to open.
I've also got CATS and AutoTap, but I heard Datamaster's the best so that's what I decided to use.
Old Feb 8, 2005 | 09:23 PM
TexasLT1's Avatar
Car: '92 RS
with Datamaster, when you open it up, go to File -> Record ALDL Data and a new screen will pop up. Then go to File -> Open, make up a filename, and hit ok. Hit Start and record for as long as you like, then hit Stop, File -> Save and you're done. Close the Record screen and you can view the file. I love Datamaster
Old Feb 9, 2005 | 01:56 AM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
LT1 edit.
Old Feb 9, 2005 | 09:12 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Originally posted by pennylessz28
LT1 edit.
Well, I already have Datamaster, so I'm gonna try and get that to work. Is there another program that you use to tune the car?
Old Feb 9, 2005 | 06:28 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
for my initial bolt-on tuning I used Ion at madz28.com he is pretty good..
After custom heads and cam I had to go to the dyno and get it tuned on the rollers by carolinaautomasters.com
if you are looking to do it by hand, have fun, I never tried it though I do have LT1 edit, I have not used it much, just to troubleshoot occasionally and load the first tune the car had..
Old Feb 9, 2005 | 10:42 PM
TexasLT1's Avatar
Car: '92 RS
It's not that bad. I've tuned mine a little bit. I had it on the dyno a while back but my cable quit working for some reason, otherwise I could have done more extensive tuning.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
