TPI on crate motor
Old Feb 7, 2005 | 08:26 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
TPI on crate motor
I am looking at buying the Gm performance motor with 290hp and around 330ft-lbs. I want to use TPI on the motor but the GM websites says use a 600cfm carb. Is this still ok to use the TPI? I would think so but I need over input. Would I gain anymore power with the tpi over a carb?
Old Feb 8, 2005 | 12:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You will most likely lose peak power with TPI vs. carb. However, the low end torque would probably be higher with TPI, as well as fuel economy.
I haven't heard of anyone who's done that particular swap. Remember, though, the 200-something HP the TPI is said to have is a net flywheel rating, meaning powering accessories, with intake and exhaust as installed in the car; while the crate ratings are gross flywheel rating, meaning no accessories powered by the engine, open headers, velocity stack on the carb inlet, etc. That crate engine actually may not end up with as much power as your current engine has.
Old Feb 8, 2005 | 05:43 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
Do you know in witch range the difference between gross and net ratings is?
Say the net ratings for the LB9 is 230hp with everything stock, how much would the gross ratings be?
Pat
Old Feb 8, 2005 | 12:48 PM
five7kid's Avatar
Peak-wise:
Exhaust manifolds cost about 15-30 HP, depending upon what follows.
Accessories such as water pump and alternator, about 15.
TPI cost the 350 HO about 40-50 hp vs. carb rating when SDPC was developing their Vortec TPI base.
The ZZ4 in 3rd gen trim reportedly put out around 300 HP vs. the gross 355 dyno HP the ZZ4 is rated at.
Dual cats was supposed to be worth 10 HP over a single factory 3" cat.
As usual, these things are a little hard to predict because of the variables involved.
What I was primarily trying to address was the originator's question that assumed a HP increase with TPI over carb.
Old Feb 8, 2005 | 03:45 PM
Car: '91 Z28
Engine: LB9
Thanks alot for the answer!!!
And sorry for high jacking the thread...
Old Feb 8, 2005 | 03:57 PM
five7kid's Avatar
No problem. Just didn't want it to appear as though I was offering a formula for net vs. gross HP.
And, just to be clear, the power loss from TPI, and the not-intended-for-TPI aspect of the 290 HP crate are why I cautioned against expecting more power. Of course, if the 305 is FUBAR, then of course the crate is going to do better.
Old Feb 8, 2005 | 04:53 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
It was a good question.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Sanjay
Aug 12, 2015 03:41 PM
