Fuel Question on LS1 Swap!!
Old Feb 10, 2005 | 11:16 AM
5.0Camaro's Avatar
Car: 1991 camaro Z28
Alright i'm getting all my parts together for my ls1 swap into my 91 camaro(FInaly ). Got about half of it together but i have a question on the fuel part. I'm going to go with a 4th gen tank since they dont have a return line. I already got a fuel pump kit from racetronics for a 99-02 camaro and i'm getting the tank this week. Is there anything else i need other then modifying the fuel lines (or getting 4th gen ones) to get the fuel work.
Justin
Old Feb 11, 2005 | 12:37 AM
5.0Camaro's Avatar
anyone?
Old Feb 13, 2005 | 07:25 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't know what swapping to a 4th gen tank costs, but you can get an external fuel pressure regulator with all the required AN fittings, adapters and braided lines for $250. Thats the route I went.
I don't know how easy/hard it would be to mate a 4th gen pump to thirdgen lines since 4th gens use alot of nylon fuel lines and quick connect fittings. It might be easier to just get a 4th gen line.
Old Feb 14, 2005 | 07:15 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
From what I remember the PCM regulates the 4th gen fuel pressure via the fuel pump. My setup uses a corvette fuel pressure regulator and the stock TPI return lines.
Old Feb 18, 2005 | 02:13 PM
CamaroCain's Avatar
Car: 88 Camaro
The fuel pressure is not regulated by the PCM, it has a regulator built into the fuel pump assembly.
The easiest way i found is going with the aftermarket regulator and lines, that is the setup i will be running for a while.
Old Feb 18, 2005 | 02:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
http://www.ls1tech.com/forums/showthread.php?t=274145
read that thread
Old Feb 18, 2005 | 02:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, nevermind.. i just realized you're the same person asking in both threads
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
