lt1 carb intake question. lt1 or lt4?
Car: 89 GTA
Engine: 350 LT1
Will the LT4 carb intake manifold fit on LT1 heads? and work? I have the chance to buy and LT4 carb intake.. cheap..
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: lt1 carb intake question. lt1 or lt4?
You need the LT4 heads to use the LT4 intake. I believe with the right amount of port work you can interchange the two. However, the raised ports on the LT4 make it an extensive amount of work.
1988iroc350tpi
Aug 14, 2015 07:52 PM
