ZZ4 Swap
Old Feb 20, 2005 | 07:57 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
ZZ4 Swap
Standard rotation water pump No. 12529305 that comes with the zz4.
Does that pump have a threaded fitting where I can install the heater hose adapter.
If there's no fitting can the hose be easily hooked up somewhere else other than hacking into the rad.
I'd prefer not to buy another pump but if I have to I will. I'm thinking maybe get an aluminum pump if I have to change it. Any suggestions as to which aluminum pump?
Old Feb 24, 2005 | 01:45 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Re: ZZ4 Swap
Well, the motor arrived today and it's got the fitting on the water pump..lol.
Old Feb 24, 2005 | 01:55 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Good to know. I plan on doing this swap also. What induction are you going with? carb or FI. keep us updated on the progress. pics are always good too.
Old Feb 25, 2005 | 11:14 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I did a ZZ4 swap from a 1992 305 TBI auto tranny. It is a torque monster now and I have to upgrade the tranny now to handle it. Nice problem to have though
Some items that I had to do/swap were:
1.) Water pump - the ZZ4 comes with a conventional one and I needed a reverse flow for the serpentine system.
2.) Had to drill and tap a 9/16 hole in the front pass. head to accomodate the A/C and smog bracket. (Aluminum is nice and easy to tap )
3.)Oil filter adapter. This is a PITA to locate. I had to go to an engine shop. I still don't understand why GM won't give you this with the engine.
4.) I went to a carb (670 Holly SA) so I had to get a fuel press. regulator and hook that up.
5.) Wiring for the tach. Not hard if you have wiring diagrams.
I shopped around for this level of HP and you would be hard pressed to get a motor like this for cheaper with the same quality. Plus it is fully assembled and can be put in the car in a weekend.
This thing MOVES now. When it hits the sweet spot (about 3500rpm) it slams you back in your seat.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
