305tpi to 350 carb
Car: 1989 Trans Am
305tpi to 350 carb
Will the carb and intake fit under the hood without modification? My 305 is on its last leg and I am going to swap out for the 350 330 HP crate motor Deluxe, and I was wondering if I had to modify the hood to make the air cleaner fit under it with issue. Thanks guys.
Transmission: 4L80E/4L80E
No modification required if you use a drop base air cleaner.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
