92 rs tbi 305, it wants to be tpi, how?
Old Mar 29, 2005 | 11:53 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hi my ant has a 1992 rs tbi 305 5 spd, with 82,000 on it, just this weekend she got a new mustang , and she was goin to trade in her car, but they were only goin to give her 1500, so now im thinkin about buying it, the car is in great shape, but i would like to convert it to tpi, what would i need and how invalved is it? also about how much am i lookin at spending on just the stock tpi swap and parts? i know she babys it and takes good care of it, so i think there should still be some good years left in her, with only 82,000 on it. what do you all think? and how much is she worth?
Old Mar 29, 2005 | 11:57 AM
Car: 92 1500p\u 2wd
is this swap even worth messin with, for the money and performacne gain? what would the performance gain be? how invalved is it?
Old Mar 29, 2005 | 01:29 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
its your friend.. and been covered over and over, and over
yes its worth it.. get a set of TPI heads as well..
Old Mar 29, 2005 | 03:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would only use a set of TPI heads and then retain your TBI. You will make more top end hp for less money with TBI than you will converting to the stock GM TPI.
After you do basic mods like headers and a full exhaust you can look into a heads and cam swap. Assuming you have the above mentioned parts you can have nearly 300hp that pulls to 6k rpm.
You can get an LT1 cam for less than 20 bucks and 081 TPI heads for less than a hundred. Chip burning stuff will run you about 200 and an intake will run you about 150 (you could even keep the stocker if you wanted, it sucks but it would suffice).
You wouldn't have to change any wiring or anything. You could even take it a step farther and get a 350 shortblock to put those parts on.
When you have TBI it is not worth switching to TPI unless you go with a better induction and more cubic inches.
Old Mar 29, 2005 | 11:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since you asked the same question here https://www.thirdgen.org/techbb2/sho...23#post2258823 , and this really isn't an Engine Swap topic, we'll let the other one handle the questions.
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
