350 question
Old Mar 30, 2005 | 01:54 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
350 question
i have recently bought a 350 block, how do i find out what kind of block it is. a roller block or something else. i want to make it a roller block. i know its a block from the 60's i think. if its not a roller block is there a way to make it a roller.
Old Mar 30, 2005 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Factory roller blocks didn't appear until 1987, so if it's from the 60s then it's not a roller block. You'll need a normal retrofit roller cam and lifters, not an OEM roller cam and lifter setup. It would be cheaper to put a regular flat-tappet cam in.
Old Mar 30, 2005 | 02:40 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
how much do the retro kits normally go for.
Old Mar 30, 2005 | 03:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lifters http://store.summitracing.com/partde...CCA%2D853%2D16
A cam (typical) http://store.summitracing.com/partde...2D12%2D432%2D8
A timing set http://store.summitracing.com/partde...art=CCA%2D3100
A cam button http://store.summitracing.com/partde...part=CCA%2D200
And you're there. Plus of course, the matching valve springs, preferably guide plates, some good rockers such as these, some push rods such as these.
Old Mar 30, 2005 | 03:33 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Also a nice timing cover that has some strength to it. Not the cheap chrome tin thickness ones on ebay. You need a strong cover due to the fact the cam button will be the wedge between the camshaft and cover keeping the camshaft from walking forward. I've also seen some water pumps that allowed the use of a center stud for additional support on the cover face.
Old Mar 30, 2005 | 06:35 PM
chesterfield's Avatar
Car: Pontiac
on the back of the block on the drivers side looking down theres a casting number. look it up on this page:
http://www.mortec.com/castnum.htm
see what ya got
Old Mar 31, 2005 | 09:25 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
thanks for the info guys. the numbers on the block are 3970014 which means that it was made between 70-76. its a 4 bolt to. but i have been doing some thinking and searching on buying a crate motor or a used motor from tacreationusa. since there like right done the road from me.
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
