How Do I Do This!!
Old Apr 4, 2005 | 10:59 PM
mrbeefy's Avatar
Car: 84' tranny
Engine: 305 H.O.
Transmission: 5-speed
How Do I Do This!!
I have an 84 t/a with a blown up 305 ho 4-bbl 5-speed computer controled engine. I have an 87 TBI truck 350 I was hoping to use but what would I need to complete the swap ? I heard I would need a 87&up TBI camaro-T/A oil pan and flywheel I know that I have to reem out the holes in my intake what else should I expect any info is greatly appreciated this is my first non- stock engine swap.
Old Apr 5, 2005 | 09:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
'87 TBI? Doesn't sound right.
Best bet would be to have your 305 heads gone through and put them on the 350 block. 1.94" intake valves would be a nice upgrade. Regardless of the truck heads, your 305 heads would be better.
You will need a 153-tooth flywheel for '86-up f-body application. Don't forget the pilot bearing if the truck was auto tranny. The oil pan on the engine should work without problems.
Old Apr 5, 2005 | 07:03 PM
chesterfield's Avatar
Car: Pontiac
when you pull the intake off the truck motor you'll notice that it is a roller block without the roller cam. you'll probably want to upgrade at this point.
Old Apr 5, 2005 | 11:43 PM
mrbeefy's Avatar
Car: 84' tranny
Engine: 305 H.O.
yup 87 old body style TBI engine I seen the throttle body& centerbolt heads too what about the fuel pump ?ill the cam push it?
Old Apr 6, 2005 | 09:50 AM
five7kid's Avatar
If the block is drilled & machined for the mechanical pump, the cam should have the lobe as well. If not, you're going to have to install an electric pump.
Old Apr 7, 2005 | 11:12 PM
mrbeefy's Avatar
Car: 84' tranny
Engine: 305 H.O.
I know aftermarket cams for 87 up engines have lobes for fuel pumps and it has a block off plate for it so probably hoping somone knew fer sher
