Does a 383's stroke effect compression?
Old Apr 11, 2005 | 01:54 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I just bought my heads for my 383 build. They are afr 195's with straight plugs and 76cc chambers.
I know that the bigger chamber generally lowers CR, but where should I plan on it being with flat top pistons and 5.7" rods?
If it's too low, would upgrading to 6" rods be a good correction?
Old Apr 11, 2005 | 02:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since compression is the total volume of the cylinder/chamber when the piston is at bottom dead center divided by the total volume when the piston is at top dead center, any increase in displacement for a given chamber size/piston crown volume will increase the CR.
6 inch rods will stick the piston tops out of the cylinders approximately .3" - not the proper way to raise compression. To use 6" rods, you need to get pistons made for them.
CR is modified/finalized by properly choosing pistons, head gaskets, and possibly machining such as shaving the heads (to reduce chamber volume) and block zero-decking.
Old Apr 11, 2005 | 02:40 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
So with a chamber that large, to get my CR to someplace useful, I am probably going to want to look at a domed piston?
Old Apr 11, 2005 | 04:31 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Or supercharge it...I like that idea better
Old Apr 11, 2005 | 06:34 PM
five7kid's Avatar
Or shave the heads to reduce the chambers to 70-72cc or so. That's pretty typical for 383/400's.
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
