couple questions
Old Apr 11, 2005 | 10:40 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
couple questions
Quick questions. Can I use a replacement 305 balancer, and my stock 305's timing cover on a 77' 350 that I'm swapping in? I take it a double roller timing chain will clear that cover as well? I've heard you have to use the 305 balancer on a swap like this in order to clear the stock belts.
Also, will I need a long or short style water pump? Thanks for any help, trying to get some basic questions out of the way.
Old Apr 12, 2005 | 09:52 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be able to use the timing cover and oil pan. There was a change somewhere in that time period, I forget when and what it was, but as long as you use both the pan and cover from the 305, it shouldn't be a problem.
The damper will most likely be a ~2 o'clock timing mark type while your stock 305 (I believe) is a 12 o'clock type. With an aftermarket bolt-on pointer, it shouldn't be a problem. Just know what you're getting when you buy the damper (or verify TDC when you put the 350 together).
You'll need a long water pump.
Old Apr 12, 2005 | 05:23 PM
84 t/a 5.0's Avatar
Weren't the 305's a one piece rear main seal though?
Old Apr 12, 2005 | 07:24 PM
five7kid's Avatar
All SBC's have a one piece seal at the damper.
Rear main seal is two-piece pre-'86, one-piece '86-on.
Old Apr 12, 2005 | 08:53 PM
84 t/a 5.0's Avatar
So I can use the pan off of my 305 on the '77 350? I've been told before that it won't work?
Old Apr 12, 2005 | 09:40 PM
five7kid's Avatar
You're right, I was only thinking about the rear main seal type. '77 will be driver's side dipstick, '84 will be passenger side.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
