LT1 swap, can it use the 749?
Old Apr 30, 2005 | 01:08 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
I'm looking to possibly swap out my tired 305 for an LT1. My question is, will I still be able to use the 749 computer for boost control on my Twin turbo bird? Does the LT1's ignition/spark control mix with 749? I've searched and read on swaps for the lt1, but nothing on the 749 computer with it.
pj
Old Apr 30, 2005 | 04:40 PM
TexasLT1's Avatar
Car: '92 RS
no, you will not be able to use the 749 unless you keep your computer controlled distributor and block off the optispark hole in the timing cover and get the intake drilled for a distributor or switch to the carb intake. you'll still need a timing pointer of some sort.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
