advice with manifold and cam.
Old May 9, 2005 | 02:27 PM
tarrent's Avatar
Ok, Please forgive me on the lag time of my responces, I am using the library computer..
I had asked about what type of cam to use in my 355 small block,
and here is the answer I recieved.
"More gear would help keep the time below 3000 RPMs at a minimum, but you're probably right in thinking it's time to change cam & intake.
A Comp XE268 or XE274 would lower the RPM band. A Performer RPM or Stealth dual-plane intake would come in sooner and pull as long as the cam would."
I know a little about performance stuff, so please bear with me.
these comp cam profiles you offered me, what type of cam is this?
is it a mid range or top end cam, or bottom end. how will this make my engine run? where will my power come on?
second q: I want to run deep gears in my car, a friend told me to install a 3.73 posi unit in my rear end. I wanted to install a 4:11
with a used corvette 6 speed. is this a bad idea.
my dad had a early chevelle with a 4:11 and a 4 on the floor, I loved the way it would plant you back in the seat a couple of inches.
will my car do this if I install the comps cams and performer manifold?
I am not rich, but I have a few k saved for this switch. I just want to spend my money on a package that works well together.
what should I do.
here is what I have done so far.
I have eibach prokit springs, global west bushings, edelbrock
panhard rod, and bigger front rear sway bars from summit.
my exhaust is a edelbrock tes header with 3 inch back to a flow master dual exit. the a.i.r. on the top of the header has been cut off and welded flush..
I installed a set of sealed power rings on my pistons, and the bottom end has been balanced.
anyways I know this is alot. but if you could give me a outline to follow, I will do it..
thanks for the help
Jeremy..
Old May 9, 2005 | 05:33 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
If thate trans is a ZF, forget it.
if its a T-56, its all good.
The XE274H is a flat tappet cam (what you need)
http://www.compcams.com/Technical/Cu...ML/128-169.asp
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 07:28 PM
mrdevontay
Sep 2, 2015 08:04 PM
