Fast Idle
Old May 9, 2005 | 06:23 PM
mouse motor's Avatar
Fast Idle
Just installed a LT-1 in my 82 Camaro it runs good but I can't get it to idle under 1625 RPM there's no vacuum leaks, can anyone help me with this problem. Thanks
Old May 10, 2005 | 01:32 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
is your TPS sensor working properly?
Old May 10, 2005 | 10:32 AM
TexasLT1's Avatar
Car: '92 RS
check the idle screw on the throttlebody? coolant temp. sensors working?
do you have a laptop and cable to hook up to the ECM? I would check what the idle is set at. also see if its throwing any codes.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
