Houston We Have A Problem.......Help..
Old May 9, 2005 | 10:31 PM
WreckIT's Avatar
Car: 1987 firebird
Engine: 5.7 L
ok I think I'm posting this in the right place if not I appoligze..
ok I have a 1987 firebird had a 305 in it , it was changed to a 350 carb then i bought it for for a mere 500.00 anyways I got a brand new in the crate 350 now what i did was take the TPI off of 1989 Iroc put it on top of the 350 wiring harness and all ecm also now it should work or atleast I hoped it would... theres something a little thing I know I'm missing and can't seem to figure it out can anybody help? I got fuel, I got spark...it trys to start but well think you know what i mean ....
Thanks in advance
Terry
Old May 10, 2005 | 07:37 AM
WreckIT's Avatar
Car: 1987 firebird
Engine: 5.7 L
LMAO
I just went back and read what I wrote not much help at all am I ..so I did a lot of searching and reading been at it all night as matter fact but I think I have all the answers I need ......
Thanks To All
Old May 10, 2005 | 05:23 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Was the 305 a TBI? sounds like a fuel pressure problem to me.
Old May 10, 2005 | 11:54 PM
WreckIT's Avatar
Car: 1987 firebird
Engine: 5.7 L
No it was TPI
I got it all done but for some reason it will not stay running it starts and dies just like that it has fuel pressure I'm thinking maybe the injectors or a couple have gone bad I'll be testing them here a few ...
Old May 12, 2005 | 08:59 PM
sellmanb's Avatar
Car: '86 Berlinetta
IIRC The 305 and 350 TPIs were differently setup. They had different sensors.
And I think that the 305 has smaller injectors than the 350...
I THINK (not completely sure, havent looked too hard into the TPI swap) that you're gunna need a 305 EST, 305 injectors, and 305 knock sensor.... though you may want to do a little searching in the general tech board for "TPI Swap" and see what all is actually needed.
Have you verified fuel pressure? BTW
Old May 12, 2005 | 11:36 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
i swapped a 305tbi to a 350tbi, i had to change the knock sensor, spark module (the one on the firewall by the brake booster) and the injectors. the 305 injectors the car would not idle. if i took my foot off the gas for even a split second to switch the gears or stop revving it the car would stall. also had to change the computer but you said you already did.
Old May 28, 2005 | 11:31 AM
WreckIT's Avatar
Car: 1987 firebird
Engine: 5.7 L
just an update it was the vats from the 89 donor car so I wired that in and the car runs now for my next minor problem the speedo is not working and I don't have a plug to it off of the 89 wirng harness I have tryed wiring from the vss ppl and yellow wires to the trans but it still not working and its setting a code 24 so that means it will not pass smog until I can get this taken care of ...any suggestions? anyone?
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
sailtexas186548
Feb 17, 2017 03:07 PM
xbmx89
Oct 31, 2015 10:59 AM
mddaniel
Sep 8, 2015 05:16 PM
hayesaw0210
Aug 23, 2015 11:15 PM
