zz4
Old May 11, 2005 | 03:12 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
zz4
So my motor took a dump on me and i was looking into the zz4 crate motor my budget is low and need to get the car running since i do not have access to a garage for to long so i can build something im gonna have to go crate
for now i will be putting the tpi setup on it just until i can gather up more loot for the carb switch but i have been reading that the tpi will not fit on the zz4 then i hear it does.
so which is it lol?
also it seems the going price for the zz4 is about 3800 does that seem right or can i shop around for a better price
Old May 11, 2005 | 05:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Fit" is relative, I suppose.
The ZZ4 heads have all of the intake base mount bolts at the same angle, like '86-earlier and Vette L98 (since they're the same heads as the Vette L98). And, they don't have the exhaust cross-over passage for EGR.
Your base can be modified by elongating the center two bolt holes on each side so you can get the bolts in. Since you're talking about a carb switch, it doesn't sound like no EGR would be a concern to you.
Other than that, it should "fit" in an '87 with no other issues.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
