LT1 Wiring Questions
Old May 15, 2005 | 09:41 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I'm starting the wiring for the LT1 harness. I've got some of it figured out, but very little. I started with the C220 and C230 LT1 connectors, and got about 4 of them to match up with the LO3 bulkhead connector. Here's what I have so far:
C230 Tachometer signal to instrument cluster - D6 on bulkhead connector
C220 Oil pressure feed to instrument cluster - E5 on bulkhead connector
C220 Vehicle speed sensor - Is it D4 or E4 on the bulkhead connector?
C220 Automatic performance switch signal - Unused
C220 Coolant temperature to instrument cluster - F5 on the bulkhead connector
Those were the only things that I found that matched up to the bulkhead connector.
1. First of all, am I starting this off right?
2. Where can I find the information for where all of the other C220 and C230 cavities connect to (feed to instrument cluster, oil level, serial data, fuel pump relay control, etc)?
3. Which ones go to into the wires in the passenger side compartment? Is there a diagram for this?
Thanks!
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
