Car wont Start, started once now no fire!!
Old May 16, 2005 | 11:53 PM
87bigblock's Avatar
I have an 87 iroc that originally had a 305 carborated motor, we put a 350 worked carborated motor in it which ran fine, now we are selling the car so we took out the 350 and put in a newly rebuilt 305 (not the orginal 305). We got the car to fire once drove it down the road but didnt quite have everything hooked up yet so shut it off and finished hooking things up. then the car had a hard time starting and fire one more time ran for a few moments and shut off. Now it will not start. Car has an HEI distributor and we have low spark. Replaced the cap, rotor, plugs, new battery, new positive cable, coil, and terminal module. Still low spark and car will not start
Old May 17, 2005 | 07:53 AM
formulajokester's Avatar
Car: 91 gta
Engine: 350 tpi
Transmission: auto
is it getting the fuel for sure?
Old May 17, 2005 | 09:33 AM
87bigblock's Avatar
yes it is getting fuel
Old May 17, 2005 | 09:49 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
Plugs look fine?
That happened to me recently..fouled the plugs after driving three miles..
Old May 17, 2005 | 09:58 AM
87bigblock's Avatar
after it started the once and then wouldnt start again, we relized it was getting low spark. so we did put new plugs in.
Old May 17, 2005 | 03:55 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
reverify your voltage & grnd at the distributor.
Old May 18, 2005 | 10:00 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i would say ground. or a coil
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
