89 GTA L98 into a 92 Z28 W/305
Old Jun 2, 2005 | 01:31 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
I bought a 89 GTA parts car for my TTA it has a strong running L98.
What issues will I run into swapping the older L98 into my 92 Z28
Seems like a stright forward swap.
Old Jun 2, 2005 | 02:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Two options:
1) Switch the entire L98 system into the '92, which would replace the SD system with MAF.
2) Put the L98 longblock under the LB9 system. Swap injectors, knock sensor, and update the SD PROM for 350 values.
Old Jun 2, 2005 | 02:45 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
I knew you'd answer, Thanks
Whats better SD or MAF, any pros and cons?
lt500r55
Sep 1, 2021 01:30 PM
IROC315
Oct 27, 2015 09:57 AM
TheExaminer
Aug 19, 2015 10:07 PM
Winchester1094
Aug 18, 2015 10:23 AM
matthew911
Aug 12, 2015 09:38 AM
