Question OF the DAY
Old Jun 6, 2005 | 09:26 PM
TEQUILA911's Avatar
Car: 1988 Z28
Engine: 355ci big cam,wrp heads,demon carb, blue printed and dynoed at 447 hp and 479 torque
Transmission: 700r4 by monster motor sports
Question OF the DAY
Summit racing has a kit to make a 350 ci engine into a 427 ci small block. Does any know if this engine good for racing? will this engine just make Torque?, Or will this engine be good for RPM and torque? Thanks Guys for your posts
Old Jun 7, 2005 | 12:40 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That kit likely will need either a 400ci sbc block, or needs an aftermarket block with spread pan rails to clear the cranks counterweights.
The 427 kits for the 400ci blocks use a 4" stroke... the same as a 454 BBC. With the right parts, you can make totally rediculous torque numbers. You could also build it to be gutless off idle, but scream to 10,000 rpm.... it all depends on how you build it.
chazman
Aug 28, 2018 03:25 PM
87iroctheo
Dec 4, 2016 11:47 AM
RedLeader289
Jan 22, 2016 03:05 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
