tpi swap help
Old Jun 26, 2005 | 11:09 AM
Snuffit's Avatar
Car: 89 formula
Transmission: t5, soon to be t56
tpi swap help
Im swapping a 88 tpi engine from a 350 formula into a 89 305 tbi formula, the 89 is a manual, and of course the 88 is a autotragic. heres the problem, everythings going smoothly accept the harness plugin that is comming off the engine harness by the computer (white/clear plugin) is pinned differently and the plugin on the drivers side dash (at firewall, by brake master cylinder/booster) is also pinned differently. Does anyone have the pinouts to these two connections? the computers seem to be both pinned correctly. and i need the harness that plugs into the drivers side dash, my headlight wireing is trashed along with other stuff, so im taking all that from the older car. which i belive is what that plugin runs. If pictures are needed for clarification of which plugs i mean just ask, ill get them.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
